If you want to open the form in the attached db you need to make sure that there is a valid reference to iGrid 7.0 in the VBA-editor.
There is no reference set at the moment because we all may have installed the OCX in different places.
If you just import the upgrade form to your db that you want to upgrade everything should be fine (as long as you have iGrid 7.0 installed and referenced).
Attaching a screenshot of the upgrade form.
Click to View Image476 View(s)
